| Re: Summing to mono always... [message #155886 is a reply to message #155877 ] |
Sat, 13 May 2006 20:10   |
Bill Mueller Messages: 4123 Registered: April 2004 Location: Joppatowne Maryland |
It sounds like you are not switching back and forth often enough. Don't wait until you are committed to a balance to check mono. Make it an every-five-minute-auto button-push thing. After a while, you will get the hang of it.
Bill
"Don't take it personally. But this shit is a science." J.J.Blair
“The Internet is only a means of communication,” he wrote. “It is not an amorphous extraterrestrial body with an entitlement to norms that run counter to the fundamental principles of human rights. There is nothing in the criminal or civil law which legalizes that which is otherwise illegal simply because the transaction takes place over the Internet.” Irish judge, Peter Charleton
| Re: Summing to mono always... [message #155930 is a reply to message #155877 ] |
Sun, 14 May 2006 02:11   |
I had a little Radio Shack 15wt amp, hooked up to a single Auratone on the 1 buss.
M
All that is neccessary for bad music to succeed is that good ears do nothing, and blow up the internet with contrived viral marketing.
| Re: Summing to mono always... [message #155997 is a reply to message #155898 ] |
Sun, 14 May 2006 11:51  |
rdolmat Messages: 260 Registered: April 2005 Location: Vancouver BC Canada |
| J.J. Blair wrote on Sat, 13 May 2006 19:27 | Mind if I ask what program you are using when you are listening back in mono?
Thank you so much folks! I guess there is no perfect mix for both.
I'm simply using the mono switch on my Tascam M3500 board to listen in mono. I used to always start my mixes in stereo and then listen to mono near the end.
Yesterday I tried to start in mono and then have a listen in stereo near the end of the mix and that's what prompted me to post this thread.
But I see now that (as everything in the studio), it's a compromise between both...leaning more toward a good stereo mix.
thanks again!!
Cheers
rich
_________________________________
www.digitalsoundmagic.com
