| pro microphone stands for drums (hints?) [message #162824] |
Sat, 10 June 2006 07:28  |
nivv_k Messages: 27 Registered: January 2006 Location: Avenza Italy |
hi there
i'm always in trouble with my cheap microphone stands
they brake they slowly goes down while recording
they are difficult to place between all the legs of the drums
expecially near floor toms
i saw really nice mic stands for toms for ex at the shellac concert at bologna
but i'm sure you can suggest me some brands or place where to buy good ones and smart choices to do their work in drum recording
thx a lot
i love when something play damned good with a good idea behind
| Re: pro microphone stands for drums (hints?) [message #168234 is a reply to message #162824 ] |
Wed, 05 July 2006 09:21   |
iCombs Messages: 542 Registered: March 2006 Location: Minneapollis |
I'd guess it's pretty solid. I can also completely vouch for the X-Tra Boom. I've got one and I used to have a Tube LDC on the end of it at full extension without so much as a hint of slipping. Plus it's great to have your top and bottom snare mics on one stand. Makes life that much easier.
Ian Combs
Producer/Engineer
Lightspeed Group, Inc.
"Mista apareeatah... can I have maar beass at all frequencies?"
| Re: pro microphone stands for drums (hints?) [message #168527 is a reply to message #167571 ] |
Thu, 06 July 2006 12:57   |
Jeff Roberts Messages: 708 Registered: May 2004 |
| philipp wrote on Sat, 01 July 2006 09:50 |
....the question is, how safe is the balance of this thing
The balance is pretty safe. It was designed for maximum stability in a small space. The patent pending base of the Latch Lake micKing stand weighs 29 pounds [13.2 kg], and over 90% of the weight is in the outer circumference where it is most effective (I learned that in Teeter Totter 101). The base of a Starbird stand is over 4 times bigger than a micKing base, but the micKing stand is more stable than a Starbird, unless the boom on the Starbird is directly over a leg.
Jeff Roberts
Latch Lake Music
LatchLake@aol.com
"When it all hits the fan, the only things left will be cockroaches and Latch Lake mic stands."
Reese Boisse
| Re: pro microphone stands for drums (hints?) [message #173754 is a reply to message #173668 ] |
Tue, 25 July 2006 13:19   |
CWHumphrey Messages: 845 Registered: August 2004 Location: Los Angeles |
While I was on staff at The Record Plant, I was introduced to Starbird booms. For overheads and strings they blew away the Atlas booms since they had a bigger base and a bigger counterweight.
With the help of Google, I just found out that Manley is now making them. EveAnna Manley has it going on!
Cheers,
Carter William Humphrey
"Indeed...oh three named one!" -Terry Manning
"Or you can just have Carter do the recording, because he's Humphrey."-J.J. Blair
| Re: pro microphone stands for drums (hints?) [message #173756 is a reply to message #173754 ] |
Tue, 25 July 2006 13:23   |
Oh, but I'll say this:
The triangle base Atlas booms without the wheels are great and they still make them. They're much, much better any of those stupid tripod stands that everyone seems to have.
Cheers,
| Re: pro microphone stands for drums (hints?) [message #175340 is a reply to message #162824 ] |
Mon, 31 July 2006 16:43   |
Blas Messages: 445 Registered: July 2006 Location: St. Louis, Mo. |
We use the Atlas 36W (as CWH posted but with wheels) both in studio and out on location. They won't slip if you snug the clutch right. A little pricey, but all the upper end ones are!
Good luck,
Blas
Conjecture and theory are all well and good...but the proof comes out of the speakers - Fletcher
He who has said the pen is mightier than the sword, has never been in a pen & sword fight!- me
| Re: pro microphone stands for drums (hints?) [message #177958 is a reply to message #167438 ] |
Fri, 11 August 2006 10:36   |
Coco Messages: 124 Registered: June 2004 Location: Canada |
You can do chin-ups on latch lake stands.
Colin G.
| Re: pro microphone stands for drums (hints?) [message #178205 is a reply to message #162824 ] |
Sat, 12 August 2006 07:37  |
Rob Darling Messages: 291 Registered: April 2004 Location: Pacific Northwest |
The Latch Lake stands kill anything else, without question.
They never, ever slip.
They take no force to get to sit right.
There is never any sag between open and closed clutch positions.
They are infinitely flexible. Articulation and angling of mics is never easier.
You can take a mic off the stand by turning the last articulation instead of turning the mic. Easy mic switch without the danger of speed clips.
Very small footprint.
Huge extension.
Space under base to coil cable for neatness.
They rock.
____________________
rob darling
rob@robdarling.net
www.robdarling.net
