| Darn kids and their questions [message #331101] |
Sun, 06 April 2008 15:03  |
Brent Handy Messages: 145 Registered: April 2004 |
Has there been a study or an experiment on this?
It is common practice to splay walls out on the sides of the control room. There are studios with the front walls leaning in and out. We all know why, blah, blah, blah. Has anyone knowledge of a designer/builder splaying the side walls, but also leaning them in or out? Foller me fellers?
| Re: Darn kids and their questions [message #331398 is a reply to message #331101 ] |
Mon, 07 April 2008 16:02   |
gullfo Messages: 125 Registered: February 2005 Location: Old Tappan, NJ USA |
i think a lot of the confusion is caused by people assuming the angled CR surfaces are boundaries... in most cases you wouldn't design the control room with angled boundary surfaces unless you had to. most designs tend to put in angled treatments so you have enough space behind them for trapping and you use panels, slats, absorption, etc on the angled surfaces to shape the space to get a proper response from baffle mounted speakers, RFZ, etc. in a live room, you can more easily get away with the angled boundary walls because asymmetry in a live room can be a good thing.
as far as angles top-to-bottom and in-out, it all depends on the amount of space and what you're trying to do... for a small room, tipping the walls out at the floor can help preserve floor space, and since you're likely making the walls pretty absorptive anyways, you're not likely to deal with strong reflections because it. if you have enough floor space, tipping them out at the top can be useful to get things moving up and into overhead traps. all in all, the amounts of different angles you incorporate into the surfaces can move the sound into more oblique angles and potentially increasing the effectiveness of absorption in the room - at the expense of increasing the complexity of the construction...
Glenn Stanton
www.runnel.com/
| Re: Darn kids and their questions [message #337050 is a reply to message #331101 ] |
Sun, 27 April 2008 15:26  |
I have to agree with almost all the points made here as being valid. IMHO, we use rectangular hard shells for most small rooms for the reasons Glenn has listed... We use angled RFZ style shells in many larger rooms, which complicates modal calculations significantly but sometimes, makes for a better ergonomic design including site lines and room arrangements. I have seldomly used walls splayed top to bottom for various design reasons... I don't see any 'reason' or 'need' to splay walls in two planes, but there would be nothing wrong with it.... just my late two cents.
fm
Francis Manzella - President, FM Design Ltd.
- Managing Director, Griffin Audio
fmdesign.com
griffinaudiousa.com
