| monitor placement advice [message #328589] |
Fri, 28 March 2008 12:45  |
lostinthewires Messages: 13 Registered: January 2008 Location: ireland |
Hi ,
I'm looking for suggestions for the placement of my Alesis m1 mk2 monitors.
My living/studio room is L 23' W 15' H 8' ; has rockwool bale basstraps in each corner and I have made six 2'x4' rfz absorbers.(4" rockwool)
The Alesis manual suggests around 3' per side equilateral triangle placement but I was wondering if I should go wider since I have a bit more space.
Right now they are at 3' and 38% back from front wall, and having read Ethan's piece are off the room center point. L is 4 1/3' from left wall and R is 5 1/2' from right wall.
I'm waiting until I finalize the monitor placement to install the rfz absorbers.
| Re: monitor placement advice [message #337058 is a reply to message #330175 ] |
Sun, 27 April 2008 15:48  |
| Barkley McKay wrote on Thu, 03 April 2008 07:12 | Thanks for the suggestions.
I have at present nearly 8 inches (after re-measuring!) of absorbtion behind, and there is definitely a better response with the speakers, bass wise, now that I have them backed up close but there seems to be a little lift in the upper bass/low mid range now.
Do you think it would be prudent to make a hanging 'cloud' bass trap above the alcove, and is it possible that I am getting ceiling to floor anomolies now?
The speakers are definitely beyond the half way point on the vertical axis. At present I do have two ceiling corner traps there (see 1st photo) but I do cherish the little window for natural daylight!
Barkley
We do a fair amount of smaller rooms with trapped front ends and almost always find that the best SPIR is by having the speaker backed up against the trapping... I imagine this keeps the wavelength for the boundary cancellation as short as possible, thus getting the fundamental frequency as high as possible.. this may explain some of the 'lift in the upper bass, lower mid range area'... almost impossible to get everything to work in very small rooms. There is just no way to avoid some of the boundary interference issues....
Francis Manzella - President, FM Design Ltd.
- Managing Director, Griffin Audio
fmdesign.com
griffinaudiousa.com
