| tube TLM103 (no, really) [message #339350] |
Tue, 06 May 2008 12:16  |
J.J. Blair Messages: 9751 Registered: May 2004 Location: by the sea & sand |
A friend of mine insisted that I play with his TLM 103 that he had David Royer turn into a tube mic. David used a 5840 submini, in a cathode follower configuration. This appears to be what he does for all tube mods.
I haven't had a chance to listen yet, but I noticed that the capsule for the TLM 103 (K103?), is a single diaphragm. This mic is touted by Neumann as having a capsule based on the K87. But how can you do that if you don't have a sympathetic rear diaphragm?
Haven't had a chance to plug it in and listen yet, but I'll try it on a female vocal later today and let you know how it sounds. I'll post some pics, too.
temporary webpage
They say the heart of Rock & Roll is still beating, which is amazing if you consider all the blow it's done over the years.
"The Internet enables pompous blowhards to interact with other pompous blowhards in a big circle jerk of pomposity." - Bill Maher
| Re: tube TLM103 (no, really) [message #341490 is a reply to message #341231 ] |
Wed, 14 May 2008 18:26   |
Klaus Heyne Messages: 1957 Registered: April 2004 |
| J.J. Blair wrote on Tue, 13 May 2008 23:56 | Al Schmitt uses M149s on piano, for what that's worth.
By itself such statement is third party info/hearsay.
Schmitt is a Neumann endorser, as can be seen on advertisements in Mix, etc.
But can you please cite proof that he is actually using M149s on piano sessions?
| Re: tube TLM103 (no, really) [message #341569 is a reply to message #341490 ] |
Wed, 14 May 2008 23:17   |
Reuben Ghose Messages: 43 Registered: January 2005 Location: Toronto, ON |
| Klaus Heyne wrote on Wed, 14 May 2008 19:26 |
Hi Klaus,
Here are two quotes on gearslutz where Mr. Schmitt talks about using M149s on piano. Actually, he also has some very kind words for you too even though he spells your name wrong!
http://www.gearslutz.com/board/chuck-ainlay-ed-cherney-frank -filipetti-george-massenburg-elliot-scheiner-al-schmitt/4806 7-al-mics.html#post482975
http://www.gearslutz.com/board/chuck-ainlay-ed-cherney-frank -filipetti-george-massenburg-elliot-scheiner-al-schmitt/4802 4-all-thoughts-capturing-vocal-acoustic.html#post484946
Reuben Ghose
http://www.reubenghose.com
| Re: tube TLM103 (no, really) [message #341605 is a reply to message #341592 ] |
Thu, 15 May 2008 03:13  |
I've seen it first hand, as well.
temporary webpage
