| Re: A Newly Discovered Fourth Element To An Electronic Circuit [message #339950 is a reply to message #339886 ] |
Fri, 09 May 2008 01:53   |
Bruno Putzeys Messages: 562 Registered: November 2006 Location: Rotselaar |
I'm a bit confused about the quote that says:
| Quote: | Chua argued that the memristor was the fourth fundamental circuit element, along with the resistor, capacitor and inductor, and that it had properties that could not be duplicated by any combination of the other three elements.
Egg-scuse me? LRC are all linear two-port elements and you can't use them to emulate diodes, transistors, fets and valves either.
| Sam Lord wrote on Fri, 09 May 2008 00:00 | This is a cool story, and made me wonder if these new devices could substantially boost performance (like S/N) of many circuits.
You can't get round resistor noise.
"Politically correct" is the politically correct term for "politically expedient lie".
| Re: A Newly Discovered Fourth Element To An Electronic Circuit [message #339973 is a reply to message #339950 ] |
Fri, 09 May 2008 06:18  |
Bill Urick Messages: 498 Registered: March 2005 Location: Atlanta |
No mention of whether this is a bistate or continuously variable component. If continuously variable they would be useful in analog computing........
which is much warmer sounding than digital computing.
Let's get one thing straight-I'm not an audio engineer and never said I was. I've just got some things I have to record.(IS)
Announcement: Since smilies are frowned upon by the ACS and it is difficult to detect subtle humor in their absence I will be substituting "(IS)" (implied smiley) where appropriate.
