| Re: MD421 repair question [message #415340 is a reply to message #415304 ] |
Thu, 02 April 2009 18:32   |
panman Messages: 229 Registered: May 2007 Location: Bern,Switzerland |
Active Member |
Hi Seth,
I did not get that "access" part, but it is true, that these new capsules are mounted totally different and don`t fit the old mics without some heavy modifications. Now, that does not mean it cannot be done, but Sennheiser would not do it.
It is also a fact, that it is not the same capsule and it does not have same properties as the old ones. It is not far away, but the old ones simply win. Besides, the capsule alone would cost almost the price of a new mic(correct me, if I`m wrong). These old capsules can also be repaired, but I would suggest your friend to buy a second-hand old-style mic. That is likely to cost less than a new capsule.
But if someone decides to fit a new capsule into an older MD421, this is a possible way:
The first pic shows the two capsules and how they are differing from each other(black:new,grey:old). The second one shows a new capsule modified with a mounting-rod from an old capsule glued into the center hole. The rod has threads on both ends, but you have to push the thick end into the center hole, that it fits tight. Closing the hole does not change the sound as I noticed and the older ones don`t have a hole anyway.
Regards,
Esa
Attachment: IMG_0909a.jpg
(Size: 261.63KB, Downloaded 397 time(s))
E.T.
| Re: MD421 repair question [message #415341 is a reply to message #415340 ] |
Thu, 02 April 2009 18:34   |
Active Member |
Attachment: IMG_0912a.jpg
(Size: 276.02KB, Downloaded 389 time(s))
E.T.
